? on runnin open Long Tubes on a 305TBI
Old May 25, 2001 | 06:08 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
im running open headers on a 305tbi, and i was having trouble with its drivability and a code 33. i found out the vacuum wasnt hooked up. that problem is fixed. BUT now, once the car warms up, it will occasionally throw a fit and backfire and cough and sputter. that **** gets loud and annoying. The tach will kinda jump around with it. it runs fine, with the exception of low torque at low rpms, and it runs out of steam pretty quick, but that doesnt affect drivability. this backfiring does. the tach will even start to dance at a light and shut off (if it throws one of those backfiring fits.
can it be timing...it hasnt been set in over two years. spark plugs are new, good msd wires, cap and rotor havent been changed in over 2 years also. (BUT THE CAR RAN FINE BEFORE HEADER INSTALL)
could it just be the lack of backpressure...and will cure itself when i put on the hi flow cat and catback?
thanks for any ideas guys
Rick
90 Camaro RS 305 TBI
Hooker 1 3/4 LTs, Random Tech Cat, Flowmaster 80 series
406 DFI on the way
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
