EGR disabled
Old Jun 14, 2001 | 12:31 PM
Magpi's Avatar
EGR disabled
Previous owner of my '83Z removed the diphragm from the EGR valve - just the rod is left sticking out. Replacing it would be problematic because I don't think there's enough clearance between where it sits on the manifold and the edelbrock performer carb I put on. Any opinions on this one? Should I make sure it's stuck closed (i.e. rod down)or replace and deal with the possible fit problems with the carb?
Old Jun 14, 2001 | 04:24 PM
Matt's Avatar
either replace it if you want or just get a block off plate instead. if it is closed and your car runs ok with out it then dont worry about it, however i was told by one mechanic that he has seen some cars with the egr blocked off burn holes in pistons. my two cents
Matt
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
