what size pipe to run inside my cat?
Old Jan 25, 2003 | 02:56 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i just removed my cat and y pipe because ill be getting my headers and y pipe on monday or tuesday and i gutted my cat and got all that crap out of there but i need to know what size pipe i need to run inside of it? i want to retain the cat look so i am running the pipe through it. i tried measuring it but one end is smaller and the other end is balled out and it looks like i gets smaller as it goes into the cat. anybody done this? if so what size pipe did you use? im goin to autozone on monday. if it matters my cat is from an 85 trans am and it had an lg4 before the motor swap.
Old Jan 26, 2003 | 12:21 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
just put a straight piece of pipe in its place, and take the heat shields off the cat, and weld them around the pipe....looks like a cat
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
knight72
Aug 10, 2015 09:32 PM
