My first exhaust upgrade?
Old Jun 24, 2001 | 03:24 PM
Joey C's Avatar
I have a 92 RS TBI, not that loud stock right now. I want an affordable upgrade for it and still keep stock cat. What should i do first. Any certain brand name items that are popular for camaros? and after 1st upgrade, what should be next? any help is appreciated.
Old Jun 24, 2001 | 05:02 PM
Jza's Avatar
Jza
Almost all the brands are pretty much the same. The only differences with some of the more expensive ones are being available in stainless steel, or being able to tune it with blockoff plates (SuperTrapp, Borla).
Generally if you want a real quiet ride, Walker/Dynomax or Cherry Bombs are the way to go, although Cherry Bombs actually hurt your flow. If you want loud, most people go with Flowmaster. Then the rest of the brands fall in between, but they're all basically the same.
Get the catback, then get headers, and do a high-flow cat at the same time. Don't forget the intake upgrades to balance it out.
Old Jun 25, 2001 | 03:59 PM
Dan87IROC-Z's Avatar
I would suggest a cat-back system from Hooker, Edelbrock, or Flowmaster. They all cost about the same (less than $300) and work great!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
db057
Apr 28, 2019 07:45 AM
J-money
Jan 4, 2019 09:45 AM
ericjon262
Sep 11, 2015 06:07 PM
84 TA NV
Sep 6, 2015 08:02 PM
Billy Decker
Sep 4, 2015 03:46 PM
