Best way to get rid of the Cat
Old Jun 28, 2001 | 10:03 PM
Jas89TTA's Avatar
My cat on my 87 Trans Am just started to rattle. I was told it's coming apart on the inside so instead of geting a new one I want to remove it. For those of you running with out a cat how did you do it and how does it sound? I have a 80 series Flowmaster on the car now. Is it best to gut the cat or remove it and replace it with a piece of pipe? If I just put a pipe in there it do you think a shop would take the clamps off and weld it for me since I removed the converter?
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, SLP Cold Air Intake, Holley AFPR, Flowmaster Exhaust, Taylor Wires, MSD Coil, Engine Pic at http://albums.photopoint.com/j/View?...200&p=49965925
[This message has been edited by Jas87T/A (edited June 28, 2001).]
Old Jun 28, 2001 | 11:17 PM
Tas's Avatar
Tas
do you even need it in Florida??if you don't just put a pipe. if you do need it, run a pipe through the hollow cat.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jun 29, 2001 | 03:29 AM
Jza's Avatar
Jza
Not here. Emissions is a non-issue. I think they should weld it if you say nothing about a cat; just say "fix this leak".
Old Jun 29, 2001 | 09:43 AM
Jas89TTA's Avatar
Thanks, I'll just put a pipe in it's place and hope I can find someone to weld it up for me.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
