How hard is it to install SLP headers
Old Jun 29, 2001 | 09:44 AM
89bonestockiroc's Avatar
I am currently in the process of swapping an engine into my 89 iroc. The new engine is still on the stand. Would it be hard to install the slp headers on a totally stock exhaust sytem? I am hoping I can do it myself in my driveway. Are there any nasty suprises that I should expect? Would it be better to wait till the engine is on the mounts? Thanks for any info,
Mike
Old Jun 29, 2001 | 02:00 PM
86SCBNJ's Avatar
I would install the headers before you drop the motor in, it will make life easier. It is still not that hard to install with the motor installed, it's just that you would probably have to loosen the mount anyway for the driver's side (if I remember correctly). I would do it will the motor is out...
Old Jun 30, 2001 | 12:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Install the passenger side header and the spark plugs, then as you're lowering the engine into the car, drop the driver's side header in. When the engine is in, then bolt up the driver's side header and install the spark plugs. Thats the way I've done it twice now and it seems pretty easy.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jul 1, 2001 | 06:45 AM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
If your lucky you won't have to dent the tube that RUBS against the steering shaft like i did, on my brand new headers!!! Lucky now i got Hooker S/C long tubes
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
Driven Daily
installed motor with AFR's and my Hooker L/T's
Kansas F-Body Association Member
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
drathaar907
Aug 6, 2015 04:20 PM
