Replacing Cat...What bolts should I use?
Old Jul 3, 2001 | 01:22 PM
91TealRS's Avatar
I'm going to replace my 91 RS's stock Cat with a Dynomax Super Converter. It didn't come with any nuts or bolts so I guess I have to go out and buy them. SO..which ones should I get? Also, my stock nuts and bolts are pretty rusted together. Do I have to cut them off or can I just get some kinda "rust be gone" stuff??
Old Jul 4, 2001 | 12:02 PM
98_1LE's Avatar
I ordered and will be adding a C & L Performance cat with SLP headers very soon.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Jul 5, 2001 | 11:46 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
To get those rusted bolts use a good penetrating fluid. The rust is only on the surface and it doesn't necessarily indicate that the threads are rusted. If the wrench has a good fit then they should come out with some effort of course. As far as the bolts go, any carbon steel bolts will do as long as you use an "Anti-Seize" compound on the threads. But if you don't want them to rust then use stainless steel bolts with Anti-Seize on the threads also.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
Amillionoh7
Aug 7, 2015 01:24 PM
