Air pump removal how-to??
Old Feb 7, 2003 | 03:49 PM
Thunderboy's Avatar
Car: '90 Camaro RS T-Top
Engine: 5.0 TBI
Transmission: TH700R4
I decided to remove the AIR pump, since I don't have to pass emissions certifications, and want to remove weight and clutter from my '90 RS 305/auto.
I already got the belt I need, but checking under the hood, I don't know how is the air pump actually mounted. I can only see one bolt at the rear (that I think holds the A/C compressor).
Where are the air pump mounting bolts? do I need to remove the 3 bolts that hold the pulley in place to gain access to the ones holding the pump?
My A/c is not cooling anything, I think it ran out of R12 coolant. Can I remove the lines at the back of the compressor, to tilt the compressor up and gain more room to work when removing the air pump? how do I know if there's pressure still in the compressor lines?
Thanks for your help,
Thunderboy
Old Feb 7, 2003 | 04:45 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
you need to remove the pump pully to get to the bolts that hold it in place, it's really easy
Old Feb 7, 2003 | 04:48 PM
Thunderboy's Avatar
Engine: 5.0 TBI
Thanks man, I'll try it as soon as I get home (I rode on my bike to work so the engine will be cool!)
Thunderboy
Old Feb 8, 2003 | 01:20 PM
MdFormula350's Avatar
a man on a mission! good luck, i would be riding my bike however its like in the low 30's and ice and snow is everywhere..
Old Feb 8, 2003 | 01:51 PM
HrdRockA4305's Avatar
BE careful! I broke 3 t-45 size torx bits trying to take that pump off. Make sure you have bits with a replacement warranty on them! Mine didn't, the craftsmans were sold out so I had to get the cheaper one.
Old Feb 10, 2003 | 08:46 AM
Thunderboy's Avatar
Engine: 5.0 TBI
Thanks guys,
I finished saturday at noon.... thing is noooobody told me the pump was held on with torx bolts... anyway, I got it all out, I can almost see my right valve cover now!! (got to remove some heater tubes)
Removing the air fittings on the manifolds were the toughest part, because there is almost no clearance, specially on the right side. I applied WD-40 the day before, and right before starting to loosen the fittings. In some cases, I used a hacksaw, to cut through the tube, so I could slip a closed end wrench. I got some plugs at a store that sells all kinds of fittings, and used a 12-point 12mm. cup to tighten the square headed plugs in place (no room for a crescent wrench there).
Hey man, no wonder you broke some T-45 bits....mine were T-40's! I had to remove the A/C compressor and ended up removing the whole cast aluminum bracket, to get the pump off (the bottom pump bolt didn't want to come off the easy way). The two bottom bracket bolts, near the water pump hose, are also Torx, so I removed them as well and replaced them with hex-headed bolts, so it will be easier to remove next time.
I will weight all the components I removed, and post it here, so anybody attempting to do this, will know how much weight can be removed. The car is running fine so far Now I'm thinking of removing the complete A/C system, already have sketches for a tensioner pulley bracket and adjuster.... but I'll try to see if the A/C can be recharged and works first. If not, I'll axe it! Year long temp here is aroung 70's anyway!!
Thanks everybody
Thunderboy
"Fast cars, fast bikes, fast women and rock'n roll"
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
