Vortec heads? Get ready to buy headers.
Old Aug 14, 2001 | 10:13 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
If you plan to use Cast GM Vortec heads, be prepared to search for new headers. On the passenger side, the farthest back bolt on a stock manifold will no go in. There is no hole in the head or even a boss in which you can drill and tap. Right now I have to deal with an annoying tick. Any good suggestions on which headers I should go with?
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Old Aug 14, 2001 | 11:48 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
what do you mean it wont go in? theres a bolt broke off in the head? there is no bolt hole? try running a 3/8 16 tap in the hole with the manifold bolted up, but not tight. those stock manifolds have a bad tendency about warping, and results in the manifold not being long enough(i know it sounds strange, but i have seen in many times at our shop) the easiest way to fix it is to drill out the holes on the end bolt holes. this makes the manifold "longer" and will let you start the bolts. when drilling out the holes, dont go much bigger than what it already is, you can also wallor(i think i spelled it right)the hole to make it fit better. hope this helps.
Wide Open Till You See God...Then Brake
Old Aug 14, 2001 | 11:51 PM
LilJayV10's Avatar
Engine: 406 Roller
i just re read your post. ooooppps. i mis read it. so there is no bolt hole there at all? i ran into this problem on my buddys firebird, 2nd gen, the 400 heads he had didnt have bolts on the outer edges. so we marked them, drilled and tapped them, they work great. sorry for the mis post.
Old Aug 16, 2001 | 01:22 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You cant use f-body manifolds on Vortec heads because that last bolt hole is missing. But headers use the inner bolt hole, so you are fine with any set of headers.
I didnt know that, I just looked on my dad's set of Vortec heads and discovered it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 16, 2001 | 05:59 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
I dare not drill into my Vortec heads. Do you guys have good recommendations for headers?
Old Aug 16, 2001 | 10:28 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Yeah, the swap meet brand. I picked up a set for $30, blasted them, now I'm going to spray them with 1500* paint that will flake in 2 weeks. Go with your prefered brand.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Soon to have:
350, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, T&R Motorsports custom air intake
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
CRFred
Feb 7, 2016 11:39 PM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
