Junkyard Cat??, What to Look for, HELP???
Old Aug 20, 2001 | 09:17 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was going to buy a high flow cat when I put my 3" Hooker aero chamber on, but I am getting gears installed and going to college. So money is tight. I want to put a cat on so I can pass emissions or at least get a waiver. I was thinking what are the chances I can find a cat at a junkyard that will fit my exhaust with Edelbrock TES headers. What size in/out do I need. Also how do I hollow out the cat so it won't hurt my air flow since most likely a junkyard will have stock ones.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 20, 2001 | 10:00 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I don't know about the junkyards where you are, but out here in SoCal they won't sell used cats. At least not at the PAP's.
Old Aug 20, 2001 | 12:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It is against federal law to sell a cat off of a junked vehicle. Most yards won't do it.
What will fit your TES depends upon which TES you got.
Hollowing out the cat is contrary to your goal of passing emissions.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 20, 2001 | 12:50 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I believe that it is actually not permitted by federal law to install a used cat on your car, and also to sell them. EPA thing.
Old Aug 20, 2001 | 01:08 PM
NTChrist's Avatar
Yeah, my 3" Catco cost me about $50 bucks from summit. Maybe just spring for that.
No guts, no glory.
Old Aug 20, 2001 | 01:59 PM
Car: 99 Formula
Axle/Gears: 342
Guess I will go with the Catco, that's what I was planning on anyways. Oh, the reason I was going to get a junkyard one and hollow it out is because, here in MD if you don't pass emissions, but spend a certain amount of money on repairs with receipts, then I could get a waiver.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
