Will pulling the hoses off the smog pump do anything good?
Old Aug 31, 2001 | 11:16 PM
Golden80's Avatar
Just a wild thought I had. The cat shouldn't work then, right? Would that hurt or help performance?
Thanks,
Matt
Old Aug 31, 2001 | 11:57 PM
rezinn's Avatar
Neither, just get rid of some clutter and allow your cat to clog easier. It will work without the air supply, just not as well.
Old Sep 1, 2001 | 12:02 AM
HrdRockA4305's Avatar
Short answer: No
Long answer:
Bad idea. Without air being pumped into your cat, it'll clog before too long and severly hurt power, and in extreme cases it may not even run from what i've heard. You won't gain any HP by just disconnecting the hoses from it either.
Now if you gut your cat or replace it with a straightpipe (illegal in every state but most places never check) and remove your AIR stuff and smog pump, you should see a slight top end power increase but also maybe a slight loss in torque. You'll have to close up the AIR ports on the exhaust manifolds too somehow. Or just get a set of non-air headers and Ypipe, but that would be almost pointless unless you already have a cat-back exhaust system.
Basically what i'm saying is this is not a free mod.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/123,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
mustangman65_79
Aug 7, 2015 09:55 PM
