Question about replacing cat with straight pipe
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I took off my cat and am replacing it with a straight pipe. My question is if anyone knows where to get the ball type flange. I see Mac has an offroad pipe for $75, but I already have the "straight" portion in place, I just need a ball flange to connect the straight pipe to the cat-back. I've seen some at the local auto parts store, but nothing bigger than 2.25". I need a 3".
Any help on where to find one would be much appreciated.
The MAC pipe can be seen here, so you can see what flange I'm talking about: https://www.thirdgen.org/techbb2/sho...c+offroad+pipe
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Try Flowmaster:
http://www.flowmastermufflers.com/we...erfMuff16.html
You might be able to find this stuff at Summit.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
i just did this on someone elses camaro and im about to do it on mine, i didnt use the flange, u put the new pipe inside the old one and clamped it down with a impact wrench then tightened it more with a breaker bar seems tight enough, doesnt leak and doesnt rattle...try that before u go spend the money on the flange
mental drawing
y pipe-reducer-clamps-pipe inplace of cat-old pipe-new pipe inside of old pipe with a clamp...
not sure if that helps or not but i thought how i explained it was hard to understand
mental drawing
transaero
Aug 31, 2015 01:14 AM
