3" slip to 3" tes weld??? right???
Old Oct 14, 2001 | 10:21 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
ok heres a question..might be dumb.....the edelbrock tes( EDL-6872) has a 3" connection to cat...now if i get a slip on 3" cat(CTO-6007) that means i cant slip the cat onto the y-pipe that came with the headers..because they are both 3" right...well my car is torn apart in the garage for the winter..i dont have access to a welder...is there a way around this without restriction..or ..is the cat just a little smaller to "slip on" to a 3" connection...
thanx
Rob
83 camaro
Old Oct 14, 2001 | 11:19 PM
rezinn's Avatar
Just take the cat to an exhaust shop and have them flare out the end of it so it will slip in, give them 20 bucks or something.
Old Oct 15, 2001 | 11:35 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
A slip on converter will slip on to the TES Header system no problem as the TES Y-pipe will be flared out so it will slip over the converter as long as it is a 3" inlet on the converter.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 16, 2001 | 12:11 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
Actually, the cat will be the piece that should have the flare on it. My direct fit Catco from summit was already flared to fit over the end of the y-pipe. But, if you have one that is not flared, just take it to an exhaust shop and have them flare the cat for you.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
jrdturbo
Mar 31, 2016 02:58 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
