No cats
Old Nov 1, 2001 | 09:00 PM
LincolnHawk's Avatar
No cats
How much horsepower/time can you add by taking off your cat?..
Old Nov 1, 2001 | 09:05 PM
Tas's Avatar
Tas
5hp maybe over a new cat. More if the cat is bad.
Old Nov 1, 2001 | 09:20 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Probably less... you'll have to make some changes to the mixture to get that power though... I'd say the best rout is a high flow cat.. probably 4 Hp difference.
Old Nov 1, 2001 | 10:21 PM
breathment's Avatar
well, if u just GUT the cat, you probably wont gain hardley and HP and might actualy loose torque, because of the turbulence created in the empty cat, so if u gut it, then place a pip inside the cat. then u will notice a little difference in sound and power.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
