True Dual?!
Old Nov 11, 2001 | 12:10 AM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
True Dual?!
OK i have an 85Z28 thats gott the factory single cat and muffler with the two tailpipes... i really dont like this... i would like to get rid of that crap and get some headers and straight pipe it with dual 'guttted' cats... the only prob is i looked under the car and under the pass. side it was made to have room for a cat and under the drivers side theres not room for it... so how would i go about straight piping it from the headers back??
Old Nov 11, 2001 | 12:35 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
You can install true dual exhaust. You need someone that is not intimidated with the work to be done . Also if you do a search of "dual exhaust" you will get alot of info on this subject.
383 86 Camaro Z28 ---1/4 mile e.t>12.89@108.8mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Old Nov 11, 2001 | 09:05 AM
Warrior's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Big454blockchevy:
You can install true dual exhaust. You need someone that is not intimidated with the work to be done . Also if you do a search of "dual exhaust" you will get alot of info on this subject. </font>
Well i will probably be doin the work so im not imtimidated but what kinda work is needed? I mean am i buyin a system from a company or fabricating it all myself? If buyin it then who makes some of the better straight pipe exhaust systems?
Old Nov 11, 2001 | 09:18 PM
shutch's Avatar
an experienced exhaust shop should be able to do it, no real problems. have them to run the pipes side-by-side in the stock location. pick a good set of turbo mufflers, some nice chrome tips, exit the exhaust in stock location (just a little lower than stock, so your tips show and everyone will know your exhaust isn't stock).
this is the same setup i had on my '85 iroc; i really miss her it will sound awesome! if you can't find a good shop there, drive to tn; i know some people. lol
e-mail me any questions. good luck!
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
