Using JB WELD on COLLECTOR PIPES? DO YOU SMELL FIRE?
Old Apr 23, 2003 | 02:22 PM
Knight350's Avatar
Hey, I have a very tiny (1cm diameter) hole on the collector pipes off the hedders... Is jb weld automotive ok to use? Or what do you think? real weld? The real problem is if it will be ok with the heat that pipe takes.
Any suggestions welcome...
Thanks guys.
Fredel
Old Apr 23, 2003 | 02:55 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If it's a hole in the pipe, I'd weld it. That area gets very hot. I don't think JB weld will take that much heat.
Old Apr 23, 2003 | 03:24 PM
Knight350's Avatar
Thanks for the quick reply, I'll take your advice and get it welded instead.
Fredel
Old Apr 27, 2003 | 10:13 PM
Odyssey's Avatar
Yeah I tried JB weld on the exhaust... it didnt last for more then a few minutes. It burned off and flaked right off
Old Apr 27, 2003 | 10:31 PM
Knight350's Avatar
Wow, well I now forget about that idea!!
Thanks for the reply. I'll just weld it soon...
Fredel
Lanz06
Sep 14, 2015 07:16 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Ranbo108
Sep 9, 2015 12:20 PM
Street Lethal
Sep 7, 2015 01:09 PM
