Smog Pump Removal Problems
Old May 22, 2003 | 11:43 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Alright, i'm in the process of removing my smog pump (belt driven) in my 1988 GTA 5.7L. Have already removed the A/C compressor and all the lines to the smog pump. Have removed at least 4 or 5 bolts from the back of the pump but the thing won't budge. Don't really want to leave the pump there but i'm really getting stressed out trying to get it out. If anyone else has run into this problem, what did you do to get it out. Thanks
Old May 23, 2003 | 12:26 AM
MdFormula350's Avatar
if i can remember when i did it, i had to remove the front pulley off of it to get to the bolts that are in front.
Old May 23, 2003 | 01:55 AM
BTS88IROC's Avatar
Mdformula is correct, I just went and checked an old smog pump assembly I had lying around and remove the 3 pulley bolts to remove the pulley and then you will have 2 more bolts to remove that is holding the smog pump itself on. Good luck.
Old May 23, 2003 | 11:11 AM
Car: 1988 GTA
Transmission: TH350
Thanks alot guys. Pulled the pulley off this morning and then the 2 bolts and the thing just fell off. Thanks again
Old Jun 7, 2003 | 03:30 AM
lanyabuddy's Avatar
What to do next?
I have an 89 RS 305 TBI and I'm taking out the smog pump. However, I don't know what to do with the hoses connected to it in the back of the pump. Can I just pull those out along with the system there(some square object) I know the two hoses in the back are for the exhaust manifolds(pass&driver) What do I do with them?
Old Jun 7, 2003 | 04:14 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Remove the lines from the exhaust,plug the holes,remove as much as possible,leave the rest,I left the lines behind the engine,difficult to remove!
Unbolt the line at the cat,plug it with a screw and some exhaust sealer,put the line back on.
Put rubber plugs on the lines still sticking out in the engine bay.
Old Jun 8, 2003 | 02:23 AM
lanyabuddy's Avatar
smog pump removed(a lot of smoke now)
Hey,
Thanks for the advice on how to remove the pump. I just have one more concern...When you remove the pump, are you suppose to be letting out a lot(A LOT) of white/grayish smoke from the mufflers? At idle, white/ gray smoke comes out and a lot more when you blow the engine....Is my stock exhaust system clogged or dirty? The engine sounds good...We plugged the hoses for the exhaust manifold and the one that goes to the back of the engine... Thanks for any advice...
Old Mar 24, 2004 | 12:48 AM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
how do you remove the pulley with it spinning?
Old Mar 24, 2004 | 03:28 AM
25THRSS's Avatar
just leave the belt on while you're doing it
92camaroJoe
Jul 29, 2023 07:57 PM
italiano67
Dec 11, 2016 09:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
