anti-frezze out the tail pipes
Guest
Posts: n/a
the heads cracked on my motor last week and the car is going in the shop soon to get fixed but my ? is this... cuz the heads where cracked it got anti-frezze in the motor and its blowing it out the exhust. so will that mess up anything ?? like the cat? i have a high-flow cat and i don't kmow if it will plug it up or not
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hey Mike,
How are ya?
I'd say the thing you have to worry about the most is the rings/cylinder walls, bearings, etc.
Antifreeze has a sneaky way of slipping past the rings into the engine oil.
And why are you worried about your cat? You didn't pass the smog test the last time with it. :sillylol:
Seriously, I don't know about the cat. I do know that running rich can cause it to coat itself from excess heat, but I don't see why the antifreeze would do that. It should vaporize with no harmful effects.
What I'd do is post this in the General/Tech Engine board and see if Vader, RB, ede, or five7kid (as well as many others) knows. Just don't use their names in the title or they won't respond.
TTYL,
AJ
How are ya?
TTYL,
AJ
Engine: 305 TBI
Transmission: th700R4
as long as your now changing and fixing anything you should be ol eapecially with the advise above,... good thing it wanst happening with engine still running normal.
good luck with the fix up
LT1Formula
Oct 8, 2015 08:34 PM
