anyone ever experiment with true duals???
Old Jun 29, 2003 | 04:15 AM
88rs406's Avatar
soon here to come my car will rarely be driven on the street so im goin to true duals and im making custom oval pipe with 1 3/4" tall custom mufflers and dump it right after the muffler, anyone ever try to do true duals to exit out the rear.
Old Jun 29, 2003 | 04:34 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Do a Search. You'll find ALOT of information.
Old Jun 30, 2003 | 11:19 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I've experimented a little bit with true duals. The setup I have now consists of Hooker 2460 comp headers going to 3" Hooker Aerochambers mounted towards the outside of the car and then the pipes exit before the rear wheels. I'm switching to a longtube setup soon here (couple of weeks) with 3" Moroso spiral flow mufflers.
You can have it exit at the rear, but the problem is that it has to go over the axle (or under) on the passenger side (no room on the driver's side). I think you can olny fit 2 2.5" pipes over the axle and that's squeezing it, however I don't know what you could do with oval pipe, I imagine you would have more room.
Old Jul 1, 2003 | 12:31 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Two 3" pipes here. Could go 3.5" if you are careful.
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
