maniflds that fit other than the EST/ESC emissions above spark-plugs style ones ?
Old Jul 27, 2003 | 07:19 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
anyoen know what exhaust manifolds will fit SBxc in third gens other than the orignal factory straight over above spark plugsstyle manifolds ? will the 79 and older manifolds that go under spark plugs clear the crosssmember in the third gens ?
how about some headers that are not expensive and that the collectors dont point straight down or back up towards front of the car one one side of the car ?
talking about whether these 70s under below spark plugs style stock manifolds will fit on third gen, three pics:
and these are the stock 80-up third gen smogger manifolds over above spark plugs that i dont want to use, caprice and truck ones have three studs instead of only two on third gen F-bodies:
i assume that the older ones will fit since they exit so far in the rear- just like the original smogger above-spark plugs style ones do.
i tried to use a set of (in the following pics) angled back version of the old 60's-'72('68 in cars) ram horns and they will bolt on and fit but damn the bottom-most exhaust stud would be in the way of the engine crossmember cradle, so thats no good unless i cut some metal out of the crossmember in which would not be a good idea..
stock GM SBC ram horns just liek what i have anbd tried yesterday on the 82 T/A 350 install:
going to try 70s log style under spark plugs style manifolds next..
hoping someoen already has and can say whether they clear everything or not.
thanks for anything at all
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
cougar20th
Aug 27, 2015 08:04 AM
theurge
Aug 21, 2015 12:46 PM
