Finally done!!
Old Aug 29, 2003 | 09:23 PM
Boxeat2469's Avatar
Finally done!!
"Some modifications may be necessary" my @ss!! But with some patience and a lot of work the new exhaust is on. 1 7/8" Hooker SuperComp Adjustable length headers with 3 1/2" collectors. Right into 3 1/2" dumps, then reduced to 2 1/2" aluminized pipe into dual FlowMasters. Sounds nice, not too obnoxious but definitely mean sounding.
Old Aug 29, 2003 | 09:52 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
why did you feel it nessasary to go with 1 7/8" headers and then only go with 2 1/2"? Seems like waaaaay overkill unless you spinning high RPMs and making huge amounts of power.
Old Aug 29, 2003 | 10:13 PM
Boxeat2469's Avatar
Not huge RPMs, but definitely huge power. The dumps will be open at the track so I can take advantage of the free flowing headers. I went 2 1/2" for two reasons. 1) I already had the Flowmaster 2 1/2" mufflers and 2) it gives better ground clearance. Down the road I'll probably go with the full 3 1/2" duals. It ran 12.20 on 9.5 psi boost. The new cog setup should be running 16 psi boost. So the big headers are gonna definitely be necessary.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
