1 1/2 or 1 5/8
Old Sep 15, 2003 | 12:44 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
1 1/2 or 1 5/8
I currently have a 305 with heddman 1 1/2 headers. I rebuilt a 350 and im looking at peak power around 3000 - 3800rpm.
Should I stick with the 1 1/2 or buy the 1 5/8. I header the 1 5/8 will benefit 3000+ rpm and kill lower flow,, is this true?
Old Sep 15, 2003 | 03:55 PM
82camaro's Avatar
Car: 82 camaro SC
If you only make power to 3800rpm you probably have some other problems. 1 1/2 to 1 5/8 is a small change and either will be fine on a stock or mild 350/305 engine. You should have no problem making power clear up to 5500+ with 1 1/2 headers.
Old Sep 15, 2003 | 10:14 PM
txhotRS's Avatar
with a STOCK 350 you should reach somewhere between 4400-4800 RPM... depending on the engine... with those headers and a decent breathing system (360* cleaner... carb... upgraded injection system) you should be good at 5200-5500, and with a nice cam... and some head work... you should be good up to 6000+
if you have 1-1/2 headers... I'd keep them... the difference between those and the 1-5/8 is minimal... UNLESS the engine is getting pretty radical or up into the 383-406 ci range
Thirdgen89GTA
Oct 19, 2015 09:27 AM
gord327
Sep 29, 2015 10:18 PM
roysatikas
Sep 22, 2015 08:15 PM
86White_T/A305
Sep 21, 2015 05:28 PM
romcjr
Sep 17, 2015 05:18 PM
