exhaust leak, help
Old Sep 24, 2003 | 04:19 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
exhaust leak, help
hey guys i have headman 68470 coated shorty headers and the headman y-pipe, i keep blowing the collector gaskets and i just bought some mr. gasket copper collector gaskets and i installed them but i still hear/feel the leak around them, the gaskets have a beveled part does that go towards the y-pipe?
Old Sep 24, 2003 | 08:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: exhaust leak, help
hey man I have the same problem. That is the problem with flat exhaust flanges. I wish i would have bought headers that came with the ball flange instead. Anyways, when i was at a car show a couple weeks ago there was a 2002 GMMG ZL1 SS camaro there with the LS6 and hit had dealer installed long tubes. This is all part of the options included on this car and I noticed that he collector flages had red RTV squeezed out of them.. I figure if it is good for a $64,000 car than I can use it on my crappy flowtechs. I have yet to get home to do it but I will try it out and post on here. There is to much surface irregulation to get these things to seal properly. Rive it a try.
Old Sep 25, 2003 | 02:35 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
anyone else? is it okay to put rtv on the collectors? those mothas get hot
Old Sep 29, 2003 | 08:32 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
You might try Permatex Ultra Copper - it's high temp stuff. I've used it on a troublesome manifold with success.
Old Sep 30, 2003 | 09:04 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I had the same problem. Went to the Flowmaster aluminum collector gaskets, and used some RED only (hi-temp) Permatex silicone sealer. 4 mos now, and no leaks. Might have been overkill, but .....who cares?
(the Ultra--Copper is designed for O2 sensors. It's not as hi-temp as the red, I don't believe. And I have NO electronics, thank ***, so I didn't have to worry about it.)
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
