sagging cat
Old Oct 3, 2003 | 11:09 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
sagging cat
ok, so my cat hangs noticably low, like you can see more than half of it when looking at the car from the side. I was thinking about heating the y pipe up with the torch and using a jack to bend it back up so that it tucks up under the car better. I was going to do an engine swap so i wasn't worried about it, but instead i ended up buying a truck and a grand worth of suspension stuff including a pro kit, shocks, and some spohn goodies, so i want to fix the cat for the time being. has anybody tried to remedy this problem this way?
Old Oct 4, 2003 | 01:50 PM
MdFormula350's Avatar
if u have stock exhaust thats the only way i would think of doing it also, or at least start cutting and make thing shorter and re-weld.
i would try what ur thinking, if i had stock exhaust and the same problem i'd most likely heat it up and try to move it up.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
