got a set of 40 series flowmasters...
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Right now im running flowtech-raptors, because they were CHEAP!...
but i just picked up 2 flowmaster 40 series, 3" in and out... And i was considering using them since my engine was out anyways..
i like the way the car sounds now, its pretty quiet but sort of sounds mopar-ish when i step on it. weird sound for a SBC...
Now i sort of like my cruising noise level... there really is non! im afraid if i put these 40 series im going to wind up with a freaking annoying cruise noise which i most def DONT want. but i like the thought of a true 40 series sound, which i must admit does sound pretty decent. I am going to wind up with a stealthram and a solid roller 234/244 cam, so its not like the motor doesnt NEED this sort of thing...
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Dude, I think I have the same mufflers you have now! The are flowtech and I'm pretty sure they're raptors, or may warlock mufflers, but they sound just like what you're describing. The car is still loud, but it's nothing to what similar cars like mine sound withe the 40 series flmasters. They are awful at cruising speeds. The do sound the best at WOT, but if you're like me, which is kind of what I got from your post, don't get the FM's. Do some reasearch on what sounds good, I know the Dynomax mufflers will fit my noise preferences. I'm going on 25 and my taste in mufflers has definitely changed in five years. I don't like that loud-all-the-time-$hit anymore.
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
delta flow
The flowmaster delta flow mufflers are available in the 40 series and sound the same on the outside of the car as the regular 40 series except the inside the car volume has been drastically reduced. (and they are cheaper than regular 40 series mufflers too through summit)
Transmission: 4l80e
Axle/Gears: 3.512
Oh, these SAY Delta flow... Maybe i should check the part numbers... that would be neat!
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 25, 2015 08:25 PM
knight72
Aug 10, 2015 09:32 PM
