Headers what do I need to remove
Old Dec 10, 2003 | 11:42 AM
joeyandkim0688's Avatar
Car: 1987 Iroc-z
Engine: 5.7
i am wanting to put headers on my 87 iroc 5.7 automatic. i am wanting to put three inch borla exhaust is this a good idea and if so what pipe should I use y,h,x pipes
Old Dec 10, 2003 | 12:09 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: Headers what do I need to remove
If you are going to be running 3" single exhaust you will want a Y pipe. H and X pipes are used in dual exhaust applications to balance exhaust pressure between the pipes.
Old Dec 10, 2003 | 12:47 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
when I installed my Hooker 2055s I didn't have to remove much. aside from the obvious removal of the old exhaust system, all I had to do was remove the AIR setup to give me more space. Of course the spark plug wires had to be removed. You may want to remove the fan switch on the passenger side of the block, because I kinda broke mine off when I put the new header in.
with long tubes you'll need to remove a whole lot more such as the starter, and probably jack up the engine a few inches. if your car is a daily driver and you don't really plan on making it a drag car, shorties will suffice. You're only getting 5-10 more hp from long tubes and its a hell of a lot more work/
Old Feb 19, 2004 | 06:59 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
even with shortys you probably will have to remove the starter if you dont have a mini starter, remove air tubes manifold, and definitly the fan switch don't knwo one person who hasn't broken thers yet when doing headers
Old Feb 19, 2004 | 07:20 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
lmfao
hectre13
Sep 8, 2015 03:38 PM
formula_novice
Sep 5, 2015 03:58 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
