Need a little advice on Cat's
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
I will be buying a set of hedman 68481 headers from ACS for my 85 305 TPI next week. Well i went to take off the bolts connecting the Y pipe and the cat and 3 of the bolts just broke off and there is no way they are coming out, so i decided i mays well buy a high flow cat while im at it. I looked at a few but im not sure what i really need to get or what some decent high flow cats are for a reasonable amount of money. I know it needs to have the AIR hookup since im leaving all the emmision stuff on for some reason. Any advice appreciated, thanks
Transmission: 4L80E/4L80E
If you haven't ordered the hedders yet, you might want to consider Hooker 2055's instead. I know they say "86-90", and Hedman says "82-92", but they're not telling the whole story. They will only bolt to '86-'90 single-cat TPI-type systems, any other will require modification - the same modifications you would have to do with 2055's.
Anyway...
Get a direct-fit Catco cat CTO-9118 from Summit. It'll mount directly to either the Hooker or Hedman y-pipe. You may have to modify the cat-back, but the '86-'90 TPI single-cat application cat-back will bolt directly to it. Since the '85 was a "bastard" year, and '86-'90 application parts are the most common offered by the aftermarket, now would be a good time to start using that stuff.
Anyway...
Car: 1985 IrocZ
Engine: Carbed 383
What kind of modifications are required with the 2055's? Will i see any noticable difference in performance or sound if i go with the hookers over the hedmens? thanks
If you get the direct-fit '86-'90 TPI single cat, you'll have to modify the cat-back to fit the cat, that's all.
LT1Formula
Oct 8, 2015 08:34 PM
