Headman Y Pipe
Old Dec 26, 2003 | 11:46 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Headman Y Pipe
I recently purchased hooker competition shorty headers for my 84 trans Am. I am also looking to buy the Borla 3in stainless steel exhaust with a 3in catco converter. I as wondering that if I change they Y pipe with a headman Y pipe of a lesser diam how much will this effect the exhaust flow? Will I loose H.P.? Will it null the fact that I have 3in pipes behind it? Also if I do purchace the Y Pipe will I have to purchace reducers for the headers or do the the 3 bolt flanges come together. Any help would be appretiated.
Old Dec 26, 2003 | 11:58 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The Hedman y-pipe has 3" collector flanges on it.
But, as far as i am aware, noone has yet posted about having tried the Hedman y-pipe on any other brand of headers, so the big question is, will it even bolt up?
As for losing any HP with a smaller y-pipe, that will depend on your current HP level. A stock 150 horse 305 may work better with the smaller pipe, while a built 350 or bigger will become choked by it.
Pete
Old Dec 27, 2003 | 10:16 PM
jimmy_mac's Avatar
I would be worried about hp loss with that Y pipe. It goes from a already mildley restrictive 2.25 inch dual pipes into a definenty rstrictive 2.5 inch singel pipe. And the collector where they meat leaves no room for the exhaust to transition. It's like hitting a brick wall.
Old Dec 28, 2003 | 11:14 AM
Then what do you guys recomend I do. I just found out that the headman Y-Pipe is designed to fit thier own specific headers. So that is out of the question. I also found out that SLP sells a 2&1/2 inch. mandrel bent stock replacement. Is this my only option? Do you guys know anyone that makes a 3in pipe? Or should I take it to a muffler shop and see if they can make me a pipe? But my friend told me that most shops won't do 3in mandrell bends. Any help would be much appretiated.
Old Dec 28, 2003 | 02:25 PM
jimmy_mac's Avatar
JCWhitney carries mandrel bent pipes all the way up to 3 inch size in both 90 deg and 45 deg. Summit does also but takes a lot longer to get them to ya. I have also heard of people gettting mandrel bends from truck parts houses. To them 3 inches is small. I have also seen mandrel bends sold on ebay for pretty cheap.
I would find an exhaust shop willing to work with you and tell them you will provide the bends. From most of the y-pipes I've seen to shortie headers they should be able to work with 90 deg and 45 deg bends.
Just find a good picture on this site of a y-pipe and use it as an example. The Edelbrock y-pipe looks real nice to me cause it only requires one mandrel 3 inch bend and it's a 45. The rest of the bends are on the 2.5 inch pipes. And the transition to the 3 inch collector looks better going into a straight pipe. I do believe there are a few good pics in the stickeys above with good y-pipes.
EDIT: OK so most of the stickies are duals. Look at this picture, http://home.earthlink.net/~chris255/thirdgen1.jpg , it would be very similar but you would use a 3 inch 2 into 1 collector after the 90 degree turn by the passenger side front tire.
And by the way that is very similiar to what my set up looks like rigth now and I used a hedman Y-pipe and cut it off right before the 2.5 inch collector and used JCWhitney bends to make the rest.
Old Dec 29, 2003 | 08:30 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
1) The hedman headers have strange location for the collector dumps, which makes the y-pipe very proprietary.
2) The y-pipe blows. I cut mine up into many peices, re-welded it back together, and replaced the 2.5" sections with 3".
3) I investigated making a y-pipe for the competition headers. Prolly the same amount of work as fixing the hedman y-pipe. Get the mandrel bends, and rent a pipe expander..
-- Joe
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
