Small mufflers...
Old Mar 7, 2004 | 02:58 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Small mufflers...
Well on my next car I'm going to be running dual exhaust. I'm gonna be running it similar to the stock system but where the cats are I want to put two mufflers. Then the system is going to end a little after that (still under the car a little infront of the rear passenger side tire) anyways I want the system to be quite...yet I cant think of any mufflers that would fit down there and be quite. the only mufflers I can think of is Dynomax race bullets...and well...those arent quite for **** O_o haha...any suggestions? Oh...I'm going to be running dual 2.5" pipes.
Old Mar 7, 2004 | 07:59 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Hey Revlimit. This might not be exactly what you are looking for but here are some threads for you to check out, including one of mine, to get some ideas. Or you could be the guinea pig we are all needing to try out one of Dr. Gasses boom tubes. But they are like $600 a pop! Hope this helps
-Anthony
Exhaust Fabrication
Oval Exhaust Pipes
Stock Car Exhaust Idea
Old Mar 7, 2004 | 11:18 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
spintech sells some flat mufflers but im not sure if they have ovalized inlet/outlets or round. heres a link to there mufflers http://www.spintechmufflers.com/spin...ntechindex.asp
go to products then go to there street perfomace section, then from there scroll down a bit where it says sportsman split case mufflers and click that and they have any size but only with a single inlet but with dual outlets. just a thought.
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
