Smog pump question
Old Mar 24, 2004 | 03:36 PM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
Smog pump question
Is it actually worth it to remove it...i been looking on the boards and all i can find is it doesnt do anything most people just remove it to get rid of weight...But there are a good bit of people that live around me sayin the could feel a diff when the pulled it off...so im confused on taking it off or not
Old Mar 24, 2004 | 06:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I raced the Camaro for a season when the '57 was down. I kept complete run records, taking the pump belt off about mid-season. If I hadn't written down that I had removed it, you couldn't have known when I did from the times.
I went to put the belt back on about a week later, and the pump had frozen up.
If you remove it for any other reason than cleaning up the engine compartment or reluctance to replace a worn out one, you're fooling yourself.
Old Mar 24, 2004 | 10:17 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It just cleans up the bay a bit. If you remove your AIR system you will have to take it off or it will eventually sieze and cause massize amounts of parasitic loss. If your AIR is entact just leave it. It weighs about 3 lbs or so and is not much eight off the front end to be concerned about.
italiano67
Dec 11, 2016 09:21 AM
Bryan F
Aug 18, 2015 02:28 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
