removing exhaust pipes
Old Apr 2, 2004 | 12:00 AM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
So I'm taking off the exhaust pipe off my car, and aside from having to cut half the bolts off, I've got a problem. I can't get the pipe out, since it goes over the rear axle. How am I supposed to get it off short of cutting it off? The replacement system I brough for super cheap is already welded together.... I am missing something or what?
Old Apr 2, 2004 | 12:43 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
I think you got it Frank. It sounds like you're laying under your car like I was, lol. When I removed mine, I had to cut it off. And since it's being replaced, cutting it doesn't matter anyway. But since your new set-up is already welded together, it's going to be tough to get it through with so little room to move around under there. If you can get the car higher, you'll have more room to move the new pipe around, and you'll probably be able to get it through.
Oh, to have a car lift!!!
Oops, you mean everything is welded together? Then nevermind to my above stuff, lol. I'm thinking you'll have to remove the Panhard Bar, a shock, a spring, and lower the axle.
Old Apr 2, 2004 | 12:48 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Yeah...i had to cut mine...not bad, but killed my shoulder for a few hours. I had to use a hand hacksaw. Hope you like pavement because you are going to be kissing it, but well worth the effort.
Old Apr 2, 2004 | 12:49 AM
Here is a pic of my stock system...you can see where I made my cuts. I had to cut behind the cat because the bolts were shot.
Old Aug 25, 2004 | 06:53 PM
stran63r's Avatar
Car: 1986 Camaro
Engine: 2.8
what size would these bolts be that you had to avoid?
Old Aug 25, 2004 | 09:12 PM
b dunn's Avatar
just take shock bolts off and support rear you'll gain room that way.
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
