View Poll Results: What headers should I keep?
SLP 1 3/4 Primaries, Stainless Steel
25.00%
ACS Hookers 2005, AIR Removed, coated y-pipe
75.00%
Voters: 16. You may not vote on this poll
SLP or Hooker
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
SLP or Hooker
Ok, I've run into a problem, and to make a long story short, I have a set of SLP Headers 1 3/4 primaries and a set of Hooker 2055. The Hookers are from ACS so everthing including the Y-pipe is coated. Obviously, I can only use one set, what would be the better of the two? I like the fact the the Hookers are coated, but the 1 3/4 primaries on the SLP's are awfull tempting as well.
Here's what I have under the hood:
355 ci estimated 360 hp, Heads ported and polished, all cleaned, balanced, and blueprinted.
Holley 58mm TB
Ported and Polished TPI
SLP Runners
Edelbrock Hi-Flow Intake
Hypertech Cap, Coil, and Rotor
8.5 mm MSD wires
Holley Billet AFPR
24lb Injectors
No smog or AIR (AIR was removed on 2055, and ordered the SLPs without the AIR)
Hopefully that is enough to give you an idea of what I'm running. They both have great things about them, but I can only use one. What would you suggest?
Holley 58mm TB
SLP Runners
8.5 mm MSD wires
Holley Billet AFPR
24lb Injectors
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: SLP or Hooker
Go with the Hookers. They are coated and your motor will make th emost of the smaller primaries. The 1 3/4" should be used if you make more power. You will be happy either way.
Car: 1991 Chevy Camaro
Engine: 305 TBI
I would also say go with the Hookers. The general consensus is that the Hookers have the best design and will support high horspower.
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
