Catalytic question
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Catalytic question
Just wondering something here. I noticed that after I installed the Magnaflow Cat that I am getting a hell of a lot better gas milleage. I used to barely make it 2 weeks without having to re-fuel and now I am going on a 2 and a half weeks and still my tank sits at 1/4. I haven't installed my new o2 sensor yet but I plan on getting that done. I waswondering if a cat can somehow increase gas milleage?
Transmission: 4L80E/4L80E
Certainly. A restrictive and/or plugged up cat will hurt power and efficiency.
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
but yet wouldn't a more flowing cat (free flow) make it so the engine runs better thus causeing you to use more gas?? im tired and may be thinking crooked
Well I had no cat on there before. It was a straight pipe from the headers back to the trunk. Litterally no back preasure whatso ever.
With non-feedback induction systems, a freer flowing exhaust leans out the mixture ratio. Feedback systems compensate for that (to some extent, anyway - MAF is better about that an SD).
If an exhaust system is restrictive, it takes engine power to "pump" the exhaust out the system. Therefore, if you remove some of that restriction, less power is required so more of the power produced by burning fuel goes towards moving the vehicle. Therefore, more net power and less net fuel consumption under cruise conditions.
Apply the same principles to WOT operation, and a free-flowing system will use more fuel - true.
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
1992 Trans Am
May 10, 2023 07:19 PM
