What Size Pipe Plug to Plug Air Tubes
Old Aug 21, 2004 | 08:14 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
ok I am Removing the air tubes from my brothers 1984 TA with a LG4 It still has stock Exhaust Manifolds. What Size and Thread do I need to plug the holes.
Old Aug 22, 2004 | 06:05 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
1/4 pipe
Old Aug 22, 2004 | 09:11 PM
RICHRAD's Avatar
5/16" inflared fitting plugs is what I used when I had stock manifolds. Picked them up at a local rubber and gasket supply house..
Old Aug 23, 2004 | 09:10 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I used 1/4" brass pipe plugs with teflon tape (both found in plumbing dept.), but I have heard that you are supposed to use 1/4" flare plugs. Mine are working fine, though, just be sure to tighten them up every now and then.
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
knight72
Aug 10, 2015 09:32 PM
drathaar907
Aug 6, 2015 04:20 PM
