symptom after exhaust install
Old Aug 25, 2004 | 03:06 PM
91redTA's Avatar
Car: 91redTA
Hi all, recently I installed headers and a high flow cat. Just today I installed a cat-back system. The headers are Edelbrock as well as the cat back with a Carsound cat. OK!. now when I rev and let off the gas, I'm getting popping sounds or possibly backfire when I let off the pedal. Is this normal? or What can I do about it? THX
Old Aug 25, 2004 | 08:28 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
thats normal, and perfectly fine
Old Aug 25, 2004 | 10:00 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
That can also be from, exhaust leaks, go over the whole system and check for any.
Old Aug 26, 2004 | 07:10 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The sounds you are experiencing are from a lean fuel mixture which typically happens when exhaust improvements are made.
Put a little more fuel in it if possible.
www.geocities.com/dzperf
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
drathaar907
Aug 6, 2015 04:20 PM
