Longtubes/true duals on a GTA?
Old Oct 18, 2004 | 02:46 PM
anondude13's Avatar
_
_
Old Oct 18, 2004 | 05:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Both are covered in the "Important/Useful Information" stickies at the top of the forum.
Old Oct 21, 2004 | 09:25 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Yes it can be done...but it is not an easy task as these cars weren't meant to have true duals run on them. if done properly you will not have any clearence problems. Honestly, I think I gained ground clearence over the stock exhaust when I had the duals put on.
Old Oct 21, 2004 | 09:34 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Most of the long tubes hang down pretty far. They will definately give you a significant performance gain. It also depends on if you have to retain your cats (your car is dual cats, right?) for smog purposes. It will have to be done custom, as nobody makes a kit or bolt on.
Good luck
Troy
So Cal
Old Oct 22, 2004 | 07:09 AM
White91GTA's Avatar
Engine: 5.7L TPI
Troy....thats a good point. I should have mentioned that but didn't. As a side note, if you run true duals, make sure to have either an x-pipe or h-pipe made while you are at it for pressure equalization purposes. when i first had my exhaust ran, i ran the pipe straight back off of each header, and the car 1)sounded like *** and 2) if you were to listen to it, one side was louder than the other due to pressure differences. so i went back and had the guy fab up a x-pipe for me and the car sounds a lot better and also runs better than with the straight pipes on it.
TX-SleeperC5
Feb 24, 2016 01:34 PM
jer4251
Sep 16, 2015 11:29 AM
Djmathis123
Sep 8, 2015 08:42 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
