Round canister style for true duals.
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
hey guys, hopfully this thread will answer some of my questions. ok ive been debating on making true duals for my car i know there has been a ton of info on the true dual word. but my question is if there are any companys that make a muffler that is a round canister style that is 2 1/2 to 3 1/2 in so that you could run true dual while retaining the mufflers and still sound good with good flow. i believe that this would be possible and still have adequate ground clearance. if any one has any info or pictures or sound clips especially on this it would be much appritiated. thanks
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
The only thing out there with the canister style and small diameter is the bullet style mufflers. I know guys run them and say they're not bad, but my expereince with guys that race using them, they are no better than open header.
Flowmaster came ouot with a new low profile muffler that is only 3" tall, but requires oval tubing inlet/outlet.
Standard case mufflers, Flowmaster has the thinest I found at only 4" so that's what I went with.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, the oval rought might be your best bet unless you wanna do some really createive stuff. Flowmaster and Spintech both make low profile mufflers.
ok do you guys think this sounds like a good idea? i was looking to get a round one but NOT a glasspack muffler. how about the flowmasters new hush power. that sounds pretty bad *** on thier site but i dont know just looking at the choices i have thanks
ok that sweet thunder link didnt work unless you wanted to show me some jewely but i was looking into that spiral flow muffler and i heard that it was really raspy sound.
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
$168-$214 for the hushpower?!?!?!? screw that. then u have to buy 2... Have you checked these out scroll down to the CHAMBERED ROUND MUFFLERS. willie used those on his true dual and it sounds great
