Anyone ever done this? Possibly stupid.....
Old Mar 24, 2005 | 12:25 PM
luvmy64's Avatar
Ive got straight through pipe (no cat) from my y pipe to the Flowmaster 80 series, and its louder than i like. I know putting a cat back in it would quieten it down some, but has anyone ever put a glass pack in front of one of these flowmasters? I realize this is probably a stupid thing to do, i just wonder what it would sound like. Opinions? Comments on other theories?
Old Mar 25, 2005 | 11:29 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
i dont really think it would be that bad of a deal honestly. I was in a similar situation as you are, no cat and my flowcrapper was just too loud. but i bought the edelbrock cat back and bolted it up. i still have no cat but it sounds beautiful! great mellow tone even witout a cat. if you want to keep your flowmaster muffler, i dont think putting a muffler where the cat is would hurt it much, it might change the tone, i'm not sure about that. if you do put a muffler where the cat is i woudl spend the money and use a race bullet or somethin durable. a cheapo glasspack from NAPA wont last long that close to the motor with all that heat, i woudl think the packing woudl burn out pretty quickly under those conditions, but maybe that would be a good thing who nows. the bottom line is, i dont think it is bad to put a muffler where the cat is if you want to quiet it down a little, just make sure it is a very good flowing muffler so you dont loose too much power.
Old Mar 25, 2005 | 07:00 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Flowmaster does make a resonator. Here's the description:
'Tuned resonator designed to be used in conjunction with Flowmaster mufflers for improved sound reduction. Helps eliminate interior resonance. Utilizes a 3.00" offset inlet/3.00" offset outlet design, measuring 4" thick x 8" wide x 12" case length'
Attached Thumbnails Anyone ever done this?  Possibly stupid.....-c-documents-settings-owner
Old Mar 28, 2005 | 05:36 PM
jbqualls's Avatar
Car: 2001 Z28 camaro
I know someone who did the same thing. Cut the cat off put a flowmaster on and it was too loud. They put a glasspack where the cat was supposed to be and it worked out. It made it quieter but still left a nice sound and didn't have a problem with the durability side of it.
Old Mar 28, 2005 | 11:16 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
well i don't know what size/engine combo you're running, but on my 'old LG4 I straight piped the cat and stuck an eighty series in place of the stock muffler on the stock exhaust system w/ dual 2 1/2 inch mandrel bent dynomax tips.
I thought it sounded real mean. Didn't go fast, but it sounded the part. Not too loud though, guess 170 horsepower doesn't get loud huh?
Brandon
LC2 TECH
Oct 13, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
mfp189
Sep 27, 2015 09:25 AM
