Not running air on a car meant for it, issues?
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Well I was wondering if I remove the air setup on my car, but it was originally equiped with it, would this affect the way it runs? Will the comp think it is now "richer" since there is no air being injected to lean it out? Just a thought, any input appreciated.
Will
Will
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i removed air on my vehicle. and it runs fine. cant ompare if it was better or not, but its not noticable either way.
I was told it would destroy the cat eventually. Figured it would mess with the a/f ratio a bit also since there is no leaning effect from the air injection
Will
Will
Car: '02 Z06
Engine: L33 5.7
I have no cat so that isnt an issue with me. and removing air will make it a tad richer, thats usually not bad either
3rdgenparts
Aug 6, 2015 09:03 AM
