Exhaust leak
Old Sep 11, 2005 | 08:08 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
Exhaust leak
ok, So apparently i have an exhaust leak which is causing my car to have many problems. (damn domino effec). anyway, i kno i have to get mny car on a lift to check it out, but what exactly am i looking for? any known points of weakness? i kno to look for cracks and holes but im 18 and this is all new to me. anyway, when i do find this leak, how should i go about fixing it? do i need to take it to a shop and welded? sorry for so many questions but id love to have my car working right.
-Adam
Old Sep 11, 2005 | 08:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well obviously you would check around all the joints in the pipes. Manifold/header-y pipe connection, y pipe to cat,cat to int pipe, muffler and tips.
If their is alot of rust on the system you could be getting lots of small holes in that case its best to replace that portion of the pipe or consider a complete system.
Old Sep 15, 2005 | 05:54 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
if it has been leaking for a long time, you might get lucky and there will be a black build up around the hole. it will look like someone spray-painted part of the pipe black. I would start at sharp curves and welds, then move to the straight sections.
also, before you put it on the lift, run the car and walk around it, listening. that way, you have an idea of where to look.
edit=confusing misspellings
Old Sep 15, 2005 | 06:22 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
look in joints and welded spots. Check the downpipe on the muffler as it has been known to crack on thirdgens. Like someone said above, look for some black soot.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
