Post your SINGLE exhaust pics!
Old Dec 19, 2005 | 09:20 PM
  #51
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I have another one of those sandwich oil coolers & the steel lines laying outside actually... waiting for my next motor!
Old Dec 21, 2005 | 04:24 PM
  #52
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
SLP 1.75" shorties into 2.5" pipes, into a 3.5" y-pipe. The intermediate pipe is 3.5" and is flanged so that I can swap from my race muffler (Borla XR1) to my street muffler (SLP TOTL, with 3.5" flange welded on). Currently it has the Borla and single 3.5" driver's side tailpipe.
Here you can see my test pipes with 2-bolt flanges for ground clearance..
  #53
Axle/Gears: 3.73:1
A shot from underneath..
Old Dec 21, 2005 | 04:27 PM
  #54
Axle/Gears: 3.73:1
And a rear shot. I welded all of this together with a Hobart MIG welder and tubing/bends from Hooker and Hedman. The y-pipe is from Flowmaster. Everything is mandrel bent and leak free, as well as modular (The tailpipe is flanged, the muffler is flanged, the overaxle pipe is flanged). If I need to drop the tank for example, the exhaust can be completely unbolted in five minutes.
Old Dec 21, 2005 | 06:05 PM
  #55
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I like that 2nd pic of the y-pipe. You got any cound clips of the system with the borla? Id like to hear how it sounds.
3.5"? Damn dude, you must have a pretty stout motor. How bout some specs?
Old Dec 21, 2005 | 07:25 PM
  #56
Axle/Gears: 3.73:1
Thanks. I don't have any sound clips yet. If I make any I will post them so you can hear.
As for specs, it has Trick Flow heads, a HSR, BBK 58mm TB, a fairly mild roller cam, forged bottom end, a Procharger with custom hard inlet pipe and two core intercooler, 42lb/hr SVO injectors, a 730 ECM with $58 code, etc. And a T56, Moser 12-bolt, and Fikse FM10 wheels.
Old Dec 21, 2005 | 07:48 PM
  #57
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Jeremy, thats exactly what I want to do. How is ground clearance?
Old Dec 22, 2005 | 01:10 AM
  #58
Axle/Gears: 3.73:1
Well, the car is lowered 2" or so, which doesn't help. Part of the reason I built my own exhaust was so that I could tuck it up against the underbody as much as possible. The transmission crossmember is lower than the exhaust so that scrapes first. The next lowest part is the exhaust crossover that goes below the oil pan. Before this setup I had a 3.5" bullet dumped before the rear axle, and it was just impossible to keep it from dragging. It also resonated pretty badly.
Old Dec 22, 2005 | 08:49 PM
  #59
LilJayV10's Avatar
Engine: 406 Roller
Again thats what I am planning on doing. I have a 406 and had true duals on it but wanted to lower the car. Traction will be the next issue.
Old Dec 26, 2005 | 02:42 AM
  #60
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Here is mine hooker 2055 y-pipe into a 40 series muffler with a 3 inch mandrel bend and a turn down. Not the prettiest setup but it sounds good and runs even better. Sounds just like a old muscle car.
Old Dec 27, 2005 | 10:38 PM
  #61
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
heres mine you can see more of it at http://darcom.org
Old Dec 27, 2005 | 11:17 PM
  #62
spills's Avatar
Car: 89 RS
Damn, nice lookin setup dude. What kinda TQ/HP numbers you pushin for 4"? Motor seems pretty damn stout, im just curious
Old Dec 28, 2005 | 12:01 AM
  #63
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
im not sure on the hp/tq but it does 11.00s and traps 126 and weighs 4000 pounds.
Old Jan 1, 2006 | 01:47 PM
  #64
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
DARCOM
I see that you had to modified the Spohn T.A., How much ground clearance do you have from floor to custom Y-Pipe.
Old Jan 1, 2006 | 08:50 PM
  #65
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
alot,, better than stock
i just sat the camera on the ground and snaped one for you
Old Jan 20, 2006 | 12:03 PM
  #66
spills's Avatar
Car: 89 RS
ok, Im about done with the 3" heddman y-pipe conversion. Its harder than I thought to expand the pipe over the old y-merger, ecspecially since its on a curve. Gimme we week or so and itll be done, with pics! Single 3", no cat into 3" dynomax super turbo
Old Jan 21, 2006 | 04:53 PM
  #67
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i dont have any pics available but i run a set of heddman headers with a heddman y pip to a guttet catalytic converter thru a 3 in magnaflow cat back.man does it sounds nice too looks bretty good also...
Old Feb 1, 2006 | 01:29 AM
  #68
Joseph Andres's Avatar
Car: 1991 GTA Convertible
here's one for you......Hooker longtubes, Mufflex Y, Mufflex 4", Borla XR-1 Muffler
Old Feb 1, 2006 | 01:30 AM
  #69
w/ muffler
Old Feb 1, 2006 | 06:03 AM
  #70
DTL504's Avatar
Here is mine a 3" Custom Mandrel Bent Y-Pipe w/exhaust cutouts for the special occassion ran into a Magnaflow 3" Y-Collector to 3" Hooker Catback system.
Old Feb 1, 2006 | 06:06 AM
  #71
DTL504's Avatar
Forgot the picture:
Old Feb 8, 2006 | 01:34 PM
  #72
Method_z28's Avatar
Car: 92 camaro z28
Forgot the picture:
Damn i wish my underbody was that clean...i gotta deal with that lake effect snow.
Old Feb 8, 2006 | 06:04 PM
  #73
spills's Avatar
Car: 89 RS
that definitely is clean lookin.
Seein as how I started this damn thread, I figured Id need to get a pic of mine on here! I finally took mine to the exhaust shop and had them finish up the 3" y pipe for me. I got it at my shop now so Ill take some pics tomorrow and post em up.
Old Feb 8, 2006 | 08:25 PM
  #74
DTL504's Avatar
I just left Chicago last Wednesday and feel your pain about that snow. Im a down south type of hot rodder. Now im in Houston 70* weather today and I had the top down after she got washed.
Old Feb 8, 2006 | 11:54 PM
  #75
Method_z28's Avatar
Car: 92 camaro z28
Yea Its very hard to find a rust free underbody third gen up here. was it that clean when you got it? It sound good with that setup? Your ride has to handle and take corners like a champ. I had to go with the hooker shorties/y pipe to the converter free borla cat back aqnd it sounds mean even for a 305
Old Feb 9, 2006 | 09:34 AM
  #76
DTL504's Avatar
I live in Chicago for 14 months but did not drive my car in the rain or snow and it garage kept during all rain and snow storms. I cleaned the underbody about 3 years ago with POR 15.
Old Feb 23, 2006 | 06:04 PM
  #77
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Mine is pretty much rust free except jsut a lil on the floor pans, i undercoated the underbody when i had the motor, trans and driveshaft out.. now all i gotta do is finish the rear end- i was plannin to do it when i install tubular panhard bar, and liftbars..
Old Aug 30, 2006 | 09:29 PM
  #78
spills's Avatar
Car: 89 RS
i wanted to bring this thread back up. Anyone else wanna add to the collection? Theres some good pics on here, which gave me some ideas for my setup. Thanks guys!
Old Aug 31, 2006 | 08:24 AM
  #79
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
another tubular cat mine's got the stock mounting bracket off the rear of the old cat. it sure was a pain cutting it off the cat. the idea suddenly came to me when i was thinking how the heck am i gonna make someting that would hold up my exhaust and fit the flared catback pipe.
Attached Thumbnails Post your SINGLE exhaust pics!-dscn0219.jpg   Post your SINGLE exhaust pics!-dscn0217.jpg
Old Oct 17, 2008 | 08:33 PM
  #80
spills's Avatar
Car: 89 RS
Re: Post your SINGLE exhaust pics!
ok, now Im really bring this back from the dead!!
Im in the process of trying to find a T56 since my T5 snapped a gear on me. So once that's cone, Im going to re-route my exhaust. As is, it was rubbing the subframe on the passenger side. On top of that, the guy who installed the kit for me threw out a nice 3" MANDREL turn down and put on some crappy press bent turn down, all nice and dinged up and scraped and everything. So Im scrapping everything and starting over at the y-pipe.
SOOO, anyone got some updates, or some more pics?
Old Oct 17, 2008 | 11:30 PM
  #81
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Fully welded. i HATE the look of clamps on exhaust. done by a local shop back home in maryland. website for muffler:
www.classicchambered.com
http://www.youtube.com/watch?v=XZjhHU4Kazo
Old Oct 18, 2008 | 12:04 AM
  #82
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
hedman headers with 3" single into 89 series flowmaster
Old Oct 18, 2008 | 12:45 AM
  #83
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Old Oct 18, 2008 | 02:33 AM
  #84
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Stainless steel.
3" Catco cat with that. Headers/Y-pipe in the future.
Old Oct 18, 2008 | 01:17 PM
  #85
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Old Nov 1, 2008 | 04:19 PM
  #86
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
Originally Posted by MattODoom
I have the hedman shorties too, havent changed the Y pipe from 2.5 to 3 yet, dont know if Ill even bother, with a "high flow tubular cat" and a 3" hooker cat back.
Sorry for lots of photos, many more at my cardomain.
MattODoom Do you have problems with your Headmans cooking your Coolant Temp. Sensor... I have a fresh 383 and headmans on my 91 Z28 and man I have to have a kevlar sleeve (made for the plug wires) wrapped around it to get a somewhat reliable temp.. still runs 250-230 F according to the gauge... but I can grab the hoses and Im not overheating
Old Nov 1, 2008 | 09:09 PM
  #87
irocin rick's Avatar
Car: 1987 Camaro Z28 LG4 4bbl
Engine: 305 LG4
Transmission: Borg T-5
Axle/Gears: 3.73 open
WOW! Everyone clean under bodies! Jealous! I got my car up on jacks right now cuse I smoked my clutch. So I felt like taking some pics. I got the summit shorty headers going in the a 2 1/2 Y-pipe into a 2 1/4 pipe to a dynomax muffler. I don't have the tail pipe welded yet. W.I.P. I suppose
Old Nov 3, 2008 | 09:20 AM
  #88
Car: 91 Z28
good to see a thread come back to life. i finally got headers on my car and the old y pipe was in bad shape so i had 2 pipes run to my flowmaster catback from the headers. it sure made a difference in how it sounds. the best part about the whole setup is when i replaced the transmission i didn't have to remove the exhaust at all. except that stupid bracket on the trans.
Attached Thumbnails Post your SINGLE exhaust pics!-dscn0852.jpg   Post your SINGLE exhaust pics!-dscn0853.jpg
Old Nov 6, 2008 | 02:04 PM
  #89
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Hooker 2210 LT's into my own custom made y pipe, Flowmaster single 3" cat back (well the pipes anyway)...BUT with a Hooker Aero Chamber muffler. Love the sound, can't wait to hear it with the new solid lifter!
https://www.thirdgen.org/forums/exha...ghlight=hooker
Old Nov 6, 2008 | 02:09 PM
  #90
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
That links is bad..try this!
Old Nov 6, 2008 | 02:58 PM
  #91
skinny z's Avatar
I had posted this earlier.
Hedman hedders.
2.5" stainless y-pipe.
Magnaflow 10778 merge pipe.
3" Flowmaster to the end.
Attached Thumbnails Post your SINGLE exhaust pics!-way.jpg   Post your SINGLE exhaust pics!-way.jpg   Post your SINGLE exhaust pics!-can.jpg
Old Nov 6, 2008 | 04:49 PM
  #92
Demon355's Avatar
How does that sound Skinny?
Old Nov 6, 2008 | 10:11 PM
  #93
skinny z's Avatar
I can't say I'm entirely thrilled with it. WOT is wonderful. As is the idle. ( I may get a sound clip before I tear it all apart ).
I don't like the medium throttle acceleration note. It gets kind of raspy. Someone mentioned that it may be the single 3" from the muffler instead of the conventional duals.
I do know that the Flowmaster muffler dosen't flow nearly enough cfm to support my horsepower level. I understand that 2.2 cfm of muffler flow per engine hp is required to have no power loss from system backpressure. Maybe that has something to do with the sound.
Old Nov 7, 2008 | 05:08 PM
  #94
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Hedman long tube headers
Magnaflow Y pipe 2 1/2" to 3"
Dynomax 3" ultra flo bullet muffler
4" of ground clearance at lowest point
Here you go!
Old Nov 9, 2008 | 04:21 PM
  #95
91Camaro's Avatar
Car: 91 Camaro
Engine: 305 TBI
I cant make my mind up on gettings tips or having turndowns.
Attached Thumbnails Post your SINGLE exhaust pics!-1.jpg   Post your SINGLE exhaust pics!-2.jpg   Post your SINGLE exhaust pics!-3.jpg
Old Nov 10, 2008 | 06:25 PM
  #96
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Nedoss, why the wrap on the pipes. Later.
Old Nov 10, 2008 | 07:38 PM
  #97
spills's Avatar
Car: 89 RS
I would assume maybe to help keep the trans temp down since the pipes are so close to the pan.
Old Nov 10, 2008 | 08:04 PM
  #98
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Two reasons, one as spills assumed is to keep the temp down around the transmission, transmission lines and fuel lines.
The other reason is my car has to be able to pass emission testing and my catalytic converter is pretty far back in my exhaust stream so I'm hoping the wrap will retain enough heat to help the catalytic converter work properly.
91Camaro go with turn downs, tips just don't look right on 3rd gens.
Street Lethal
Apr 30, 2019 12:14 PM
BADNBLK
Nov 16, 2016 09:12 AM
aaron7
Aug 17, 2016 06:02 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
TheExaminer
Aug 26, 2015 04:59 PM
