CA compliant cats?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Hey fellow SoCal'er!
Are you asking about replacing the catalytic converter or the O2 sensors?
You only need to replace either part if you fail a smog test because your emissions are too high. The cat-con will really reduce your emissions while the O2 sensor is what gives you great fuel mileage and makes the car perform its best while cruising. If its been 30,000+ miles since the O2 sensor was last replaced, then I would go ahead and replace it.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Just the Cat. Like Kevin said if you have high milage on your O2 sensor than you might want to consider replacing it.
LT1Formula
Oct 8, 2015 08:34 PM
