Catback--To weld or clamp together??
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Basically right now my exhaust system is as follows:
Heddman 68470s
Heddman y-pipe, mod'd for true single 3"
3" test pipe
3" walker I-pipe
3" walker over-axle pipe
3" dynomax super turbo
So, basically I was thinking about clamping most of it together with butt and lap joint clamps, if I never need to take it off. I dont wanna use u-bolts because for me to get it to seal properly, it usually ends up crimping the pipe making it impossible to get off. But I started thinking, other than the test pipe, would I really need to take any of the exhaust off? Basically the i-pipe and over axle pipe. Im just wondering if overall it would be better to weld it all up rather than spending $8.50 a pop on freakin clamps.
Heddman 68470s
3" test pipe
3" walker I-pipe
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
You can clamp it if you need to temporarily, however I would STRONGLY recommend you get it welded.
Car: 89 RS
well is there anythign other than the cat or testpipe that would need to ever come out to get to other components?
no green
Jan 9, 2016 09:22 PM
