Something comparable to SLP
Old Jan 9, 2006 | 02:04 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I've got the SLP 2OTL side exhaust on my Formula. Recently,I've been considering going back to the traditional duals look but would like to keep the sound and characteristics of the SLP muffler. I've used a few different brands in the past and at this point don't want to use them again such as Flowmaster and dynomax. My other choice is a little over the top but I'm willing to try it if all else fails. That option would be to keep the SLP muffler and get the needed tubing to run a tailpipe from the left side around the muffler and out the passenger side. I have seen this on the Magnaflow website and think it will do the trick but wanted to get a few opinions and thoughts first.
Old Jan 10, 2006 | 11:59 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would look at the Hooker Aerochamber cat-back.
Old Jan 10, 2006 | 01:35 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Another vote for Hooker mufflers. They sound awesome and perform very well too!
Old Jan 15, 2006 | 08:43 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
should call SLP they make a dual out rear like you want...
Old Jan 15, 2006 | 10:27 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Check Ebay, you can usually get a new SLP oem piece for the LS1 SS cars for around $100 - $150. They are all stainless. They even have stainless tailpipes, but are bent at obscure angles requiring the SLP Dual-Dual Tips if you dont want crooked tips.
Old Jan 28, 2006 | 07:17 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I say go for it if you dont like the look. Would be easy to do and i dont see how it would hurt performance much. Have the shop cut and reweld the tip so it matches.
IM installing this same system on my car right now, with a cutout for the track. Havent had a chance to fire the car yet. But i love the quality of SLPs catback. Should sound good with a big inch sb pushing thru it.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
