2.5 vs 3 y-pipe
Old Jan 15, 2006 | 05:56 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
2.5 vs 3 y-pipe
I have a mildy modded 350 TPI, (SLP runners, ZZ4 Cam) with hedman shorties and 2.5" y pipe. There is no cat, and a 3" hooker cat back.
Am I going to see a difference worth the $40 to change the y pipe from 2.5" to 3"?
Thanks,
Matt
Old Jan 16, 2006 | 10:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are you talking about both pipes being 3" or both pipes being 2.5" and joining to become 3"? The latter is the better setup for a street car. Dual 3" pipes is way too big for a 300+ HP engine.
Old Jan 16, 2006 | 10:08 PM
MattODoom's Avatar
Car: '88 G T/A
as it is now it is two pipes that come from the collector and y into a 2.5 and then dump into my 3" catback. Im wondering if itll be worth $40 to convert the ypipe to be 3".
Old Jan 16, 2006 | 10:27 PM
Kevin91Z's Avatar
Ok, yes it is worth it to have the outlet of the y-pipe be 3". Think about it. Four cylinders each flowing into 2.5" then merging to eight cylinders flowing thru a 2.5" outlet. You know that has to be restrictive.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
