spin tech
Old Mar 1, 2006 | 11:19 AM
slim84maro's Avatar
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
spin tech
spin tech any good?
Old Mar 1, 2006 | 11:39 AM
sstpres's Avatar
Spin tech
I've got a 4" Spintech muffler behind a 4" single exhaust on my 83 TA. Sounds pretty wicked.
Seems to flow good also. Running high 11's through full exhaust.
Old Mar 1, 2006 | 12:57 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
Do you have the oval pipes?
I was thinking about going with dual 2 1/2in with 2 mufflers under my 84camaro.
Ground clearance problems with round dual pipes.
Old Mar 1, 2006 | 01:10 PM
sstpres's Avatar
Spintech Mufflers
I have long tube headers and a Mufflex exhaust. 3" Y to 4" single exhaust. No CAT. Clearance is good. No lower than the header collectors.
The system is easy to install. However, aftermarket torque arm clearance may be a problem.
Kelly
Old Mar 1, 2006 | 01:35 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
right now i have headman shorty header with collectors welded to 2 1/2in pipes to about the center of the car with 2 pro flo mufflers. i have about 7-8in of clearance on the passanger side and about 5 in on drivers side, i though i wouldent beable to get the oil filter off if i put the pipe too close to it. i plan on moving it up soon though and alittle to the side.
sheachopper
Jul 31, 2019 11:27 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
