Will Cat choke stroker?
Old Mar 3, 2006 | 12:28 PM
Ratchet's Avatar
Will a catalytic converter choke the exhaust enough to make it idle poorly. I'm talking about a 383 with a ex284hydralic cam.
Ric
Old Mar 3, 2006 | 12:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It depends on how much power you make and what size exhaust pipe you use. High flow cats do not rob power like they used to. As long as you size your exhaust correctly, and use a high flow cat, you won't restrict the system. If you are really concerned your best bet is to run an cut-out for the times when you need every last pony.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
