Header Install
Car: 1989 gta
Engine: 350 tpi
Transmission: 700 r4
Header Install
I own an 89 gta with mac headers and need to change the head gaskets,wondering if anyone knows what has to be done to remove the headers? Looks like I might have to remove the steering shaft on the drivers side? Not sure about the passenger side yet,any help would be appreciated!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You shouldn't have to remove the steering shaft. You should be able to remove the y-pipe and starter and have ebough room to remove them from the bottom. Many driver side headers will come out from the top. When in doubt remove the two enging mount bolts and slighty jack the motor up. That will usually give you enough room to get at all the bolts and remove the headers from under the hood.
