corvette lt1 manifolds on thirdgen?
Old Apr 18, 2006 | 12:24 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Right now I have some hedman longtubes but they leak and I'm looking for a better solution. Also another problem is finding some headers with the d port exhaust flanges. I found corvette lt1 manifolds that have the d port style, but will they fit? I'm sure the manifolds will bolt up but will it clear the crossmember if you bent a mounting pipe?
Old Apr 18, 2006 | 04:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Hedman makes a set of 3rd headers with d-ports. You can also use SLP shorty 1-3/4 and some run Hooker 2055's. A quick search should give you more answers. To my knowledge vette manifolds will not work because of the collector location (right down the side of the motor which leaves no room for a y-pipe).
Old Apr 18, 2006 | 07:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Corvette manifolds dump in the middle IIRC, so they will not work, as you have a chassis directly under there.
Frozer!!!
Jan 19, 2024 04:55 PM
transaero
Aug 31, 2015 01:14 AM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
