Full exhaust help
Old May 8, 2006 | 11:23 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Full exhaust help
Does anybody know if you can fit a full exhaust on a 1987 camaro 5.0. I want to put on two straight pipes and two mufflers , and of course two catalytic converters. But I don't know if it will all fit.
Old May 8, 2006 | 11:28 AM
TABANDIT's Avatar
Car: 1987 Transam
Engine: 1991 350 Bored .030 over
Transmission: TH350 w/stage 2 shift kit
Do a search, this question has been asked many times and has alot of pages dedicated to it.
Old May 8, 2006 | 12:10 PM
antscrd's Avatar
Car: 91 z28/2014 charger
Engine: 350/ v6
Transmission: 700r4/ auto
in order to fit two cats, you'll have to do some bending on the floorpan or you'll probably drag on eveything. i think two cats will require other mods, but i could be wrong. why not do true duals run in stock location, no cat? i would also suggest a good set of headers.
Old May 8, 2006 | 07:40 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Is there a comapany that makes a smog legal full dual exahust for 1987 IROC? Because I have a Y-pipe and ahhh....it is just not the same.
Old May 8, 2006 | 11:44 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
You can run true duals
All you need is two cats from a later model car. From there, cut the Y off your y-pipe, then tie in your two late model cats.
Go to the sticky with the pics and you'll see some good ideas. Mine is there too.
Old May 10, 2006 | 08:17 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Thanks for the information. Iwill most likely do that in the future.
customblackbird
Aug 15, 2021 10:16 PM
Dyno Don
Jan 24, 2016 08:24 AM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
